Issues Found While Generating DVAT 16 Using Offline Block
For Annexure 2B e-VAT template, when commodity details are specified for interstate transactions, the DVAT offline block does not validate those transactions. This is a template issue and not related to the product.
The following error messages appeared when Advanced Import and Preview buttons are clicked:
●      Advanced Import: Index and length must refer to a location within the string. Parameter name: length.
●      Preview: The Microsoft Jet database cannot open the file. It is already opened exclusively by another user, or you need permission to view its data.
When transactions are entered without specifying the commodity name and commodity code, the tool was requesting for commodity details in Column 5B. However, when the details are provided, the same error messages appeared as explained above.
