Increase of Output Tax
In Tally.ERP 9, you can create a journal voucher to account for the increase in output tax.
To create journal voucher for increase of output tax
1.     Go to Gateway of Tally > Accounting Vouchers > F7: Journal.
2.     Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
●      In the Stat Adjustment Details screen,
o      Select the option VAT in the Type of duty/tax field.
o      Select the option Increase of Output Tax in the Nature of adjustment field.
o      Select the option Advance Tax in Additional Details field.
o      Press Enter to save and return to voucher screen.
3.     Debit the ledger grouped under Current Liabilities.
4.     Enter the amount in the Debit column.
5.     Debit the VAT ledger.
o      Enter the Rate and Assessable Value in the VAT Details screen.
o      Press Enter to return to voucher screen.
6.     Set the option Provide VAT Details to Yes, and enter the relevant details.
Note: The option Provide VAT Details is provided as per state specific requirements of VAT/CST forms and annexures. In this example, the State is selected as Bihar.
7.     Enter Narration, if required.
8.     Press Enter to save.
