Job Work in Tally.ERP 9
Tally.ERP 9’s simple yet powerful Job Work feature enables you to record transactions related to Job Work with ease. The Job work functionality in Tally.ERP 9 has the following features:
●      Simple and user-friendly
●      Quick and easy to set up and use
●      Job Work Out Process
o      Record Job Work Out Order by capturing the details of Components to be issued and Finished Goods /Scrap to be issued
o      Account the Receipt of Components towards a Job order or directly record the Material receipt by creating the Job Order.
o      Flexibility to account the Receipt of Finished goods without raising Job Work Out Order and Material In voucher
o      Track cost against the Job Work Out Orders
●      Job Work In Process
o      Record Job Work In Order by capturing the details of Components to be received and Finished Goods /Scrap to be delivered
o      Flexibility to account the delivery of Finished goods without raising Job Work Out Order and Material In voucher
o      Track the Own Consumption of Goods against the Job Orders and Bill the same on the Principal manufacturer
●      Generate Annexure II for Removal of Goods for Job Work
●      Maintain and Generate Annexure IV (by Principal Manufacturer - if excise applicable)
●      Maintain & generate Annexure V (By Job Worker - if excise applicable)
●      Reports
o      Generate Order Outstandings report for Orders & Components
o      Generate Job Work Registers such as Job Work Out Order/Job Work In Order
o      Material Out Registers
o      Material In Registers
●      Material movement Register
o      Provision to view the details of Stock lying with the Job worker and ageing of the stock
o      Provision to generate the report to analyse the variance in issue of components and receipt of finished goods and vice versa.
