Changing Password
You can change your Tally.NET password at your convenience. As per the best practices available, it is recommended that the password should be changed frequently in order to avoid unauthorised access to business information.
To change the password
1.     Go to the Control Centre.
2.     Click P:Change Password.
The Change Password screen appears with the Username.
3.     Enter the current password in Old password field.
4.     Enter the new password in New Password field.
5.     Repeat the new password in Repeat field for the purpose of confirmation. The Password Strength indicator displays the strength of the new password.
Note: To understand the conditions that determine a Password's strength, click Password Strength Indicator.
6.     Press Ctrl+A to accept the new password.
