Periodic Payments and Receipts (India)
The Periodic Payments and Receipts provides the list of recurring Ledger Vouchers based on the Ledgers identified by the Auditors. This report also provides the comparison of Ledgers Vouchers with previous years Vouchers to analyse the deviations if any.
To view the Periodic Payments and Receipts
1.     Go Gateway of Tally > Audit & Compliance > Audit & Analysis > Period Payments and Receipts.
The report provides the details of total amount spent or received along with the total number of Vouchers during each year. It also provides the details of the Amount and Voucher variance which can be used to carry on the further investigations.
Button options in the Periodic Payments and Receipts report
F4: Group
Click F4: Group or press F4 to filter the Periodic Payments and Receipts belonging to the selected Group.
F8: Show Ledger
Select the required Ledger and click F8: Show Ledger or press F8 to view the Ledger Vouchers report for that Ledger.
Ctrl+F9: Master Config
Click Ctrl+F9: Master Config or press Ctrl+F9 to identify the parties as MSME, Related Parties, Periodic Ledgers and apply Sampling methods for Auditing.
W: Working Note
Click W: Working Note or press Alt+W to specify the working note details at Company or Group or Ledger level. The details provided in working note will be captured in Audit Working Paper along with the details of User Name, Working Note Date and Time, Status, Note and so on.
F9: Inv Reports
F10: Acc Reports
F10: Audit Reports
F12: Configure
●      Show Name of Group: Set this option to No to hide the name of the immediate Group/Subgroup.
●      Show ledgers with Variance: User can choose to view only those Ledgers that fulfill.
●      Variance Type: The user can choose to view the variance based on amounts, or percentages.
●      Range:The user can choose to view Ledgers with variance equal to, greater than, or lesser than a specific value:
The value has to be specified in the next field:
●      Appearance of Names: Select the required Display Name for the Periodic Ledgers.
●      Scale Factor for Values: Select the required scale factor from the list to display the amount in the respective denomination.
●      The Auditor can press Enter on any of the Ledgers to view the Periodic Ledger Monthly Summary report.
