Using Credit Limits
You can set credit limits for ledgers accounts grouped under Sundry Debtors and Sundry Creditors at the time of ledger creation or from the alteration screen or also at the time of invoicing.
To enable credit limits feature
●      Go to F11 Features > Accounting Features.
●      Enable the option Maintain budgets and controls.
To set credit limits for single ledger
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Create or Alter
2.     Select the required party ledger from the list of ledgers to set credit terms.
3.     Set the required credit limit.
4.     Enable the option Override Credit limit using post-dated transactions, if required.
To set credit limits for multiple ledgers
1.     Go to Gateway of Tally > Accounts Info. > Ledgers > Credit Limits
2.     Select the required group of ledgers from the List of Groups to set credit terms.
The Multi Ledger Limit Alteration screen appears as shown below. The list of ledger accounts under the selected group is displayed.
3.     Set Credit Limit, Credit Period, and Check For Credit Dates During Voucher Entry in the Multi Ledger Limit Alteration screen.
To view this report for a different group
●      Press Ctrl+F4.
●      Change the group in the Select Group screen.
