Job Work Out Order for a Stock Item Without BOM
In business scenario a manufacturer who wants to delegate the manufacturing Job to an external manufacturer (Job Worker), first identifies the Job workers who have specialisation in the Job which needs to be delegated. Then compares the cost of manufacture by different Job Workers and finally decides on the Job Worker to whom the job to be delegated based on cost of Manufacture, Quantity of Manufacturer etc.
After deciding the Job Worker Principal manufacturer raises the Job Work Out Order by specifying  the details of Finished Goods to be manufactured and expected Quantity of Finished Goods, Raw material to be supplied by the Principal Manufacturer, Date of Delivery of Raw Materials (if delivered in installments) etc.
In Tally.ERP 9 users can record Job Work Out Orders using Job Work Out Order voucher.
under this we will learn to record a Job Work Out Order for a stock item for which Bill of Material (BOM) is not created and all the material required will be delivered at once.
Example: On 4-12-2010, ABC Company delegated the Job of Manufacture of 500 nos of 12Litre Cooker to Mega Manufacturers. To manufacture of 12 Litre Cookers following Raw Materials will be supplied by ABC Company.
Raw Materials
Quantity
Bottom Plate-12Ltr
500 (Nos)
Lid Aluminium Plate-12 Ltr
500 (Nos)
Handle (8 Ltr
1000 (Nos)
Packing Box (12 Ltr)
500 (Nos)
Hand Book
500 (Nos)
The following scrap produced will be returned to the Principal Manufacturer
Scrap
Quantity
Aluminium Scrap
25000 (GM)
1. Record the Transaction in Job Work Out Order
To record the Job Work Out Order
Go to Gateway of Tally > Order Vouchers > J: Job Work Out Order
  1. Enter the Date as 4-12-2010
  2. Party A/C Name: In this field select the Job Worker ledger on whom the Job Work Out Order is raised. E.g. Mega Manufacturers.
  3. In Party Details screen, under Process Instruction section specify the duration of Process and Nature of Process to be carried out.
  4. Duration of Process:  In this field enter the duration of the manufacture of finished goods. i.e. within how many days/months etc. the process to be completed and goods to be delivered.
  5. Nature of Processing: In this field specify the details of nature of process (process Instruction) to be carried out to manufacture the expected finished goods.
Note:
1. The Party Details screen will be displayed while recording Job Work Order only if the option Accept Supplementary Details option is set to Yes in Job Work Out Order Configuration.
2. Providing details in Duration Of Process and Nature of Processing in Job Work Out Order is not Mandatory. However while transferring the goods to the Job Worker it is must to define the Nature of Processing. When material transfer out are recorded by tracking the Job work Out Order then Duration and Nature of Processing details  will get captured automatically.
  1. Order No: In this field enter the Job Work Out Order Number. E.g. Job - 001
  1. Name of Item: In this field select the stock Item i.e. Finished Goods to be manufactured by the Job Worker. E.g. Cooker 12 Litre. Press Enter to view Stock Item Allocations screen
Note: In case the Manufacturer does not want to track the Raw materials then set the  option Track Components to No. When this option is set to No, Tally.ERP 9 will not display the Component Allocation Screen.
Note: If the Principal Manufacturer has agreed for the delivery of finished goods in Installments the user can define multiple Due on date with Quantity of delivery.
Example: 500 Nos on 20-12-2010 and 500 Nos on 6-1-2011
Note:
1. Component Allocation screen will be displayed only when the option Track Components is set to Yes in Stock Item Allocation screen.
2. The Finished goods for which Job Work order is raised does not have the Bill of Material (BOM) then in Component Allocation screen, Tally.ERP 9 will skip Fill Component using field and cursor will be displayed in Name of Item field indicating that the Raw Materials required for the manufacture of Finished goods has to be selected from the List of Stock Items.
Note: Based on the Job Work Order Tally.ERP will highlight the appropriate Type of Component.
* For Job Work Out Order - Pending to Issue will be highlighted
Note: If the Job Worker has agreed for the delivery of raw materials in Installments then user can define multiple Due on date with Quantity of delivery.
Example: 100 Nos on 6-12-2010 and 900 Nos on 7-12-2010
Note: Cursor will not move to As per BOM field when the BOM is not selected in Fill Component using field.
Note: While recording the Job Work Out Order users can also track the Scrap, By-Products or Co-products produced during the manufacture of Finished Goods.
The completed Components Allocation screen is displayed as shown
Note: ABC Company wants to track the total cost incurred for the manufacture of 12 liter Cooker for the Job -001 delegated to Mega Manufacturer.
The completed Stock Item Allocation screen is displayed as shown
The completed Job Work Out Order is displayed as shown
  1. Press Enter to save.
The details of Job Work Out Order details can be viewed in
To view the Job Work Out Orders Book
Go to Gateway of Tally > Display > Job Work Out Reports > Job Work Registers > Job Work Out Orders Book
Job Work Out Order (for Excise Stock Item)
When the Job work order of excise stock items are given, to capture the transaction details in excise reports the Job work out orders have to be recorded in excise voucher types.
Step 1: Alter Job Work Out Order Voucher Type
Go to Gateway of Tally > Accounting Info. > Voucher Types > Alter > Job Work Out Order
Step 2: Record the Transaction in Job Work Out Order (We will record the transaction for the example given above)
  1. Enter the Date, Select the Job Worker ledger and in Party Details screen specify the Process Instruction - Duration of Process and Nature of Processing
Note: Providing details in Duration Of Process and Nature of Processing in Job Work Out Order is not Mandatory. However while transferring the goods to the Job Worker it is must to define the Duration of Process and Nature of Processing.
  1.  Enter the Job Order Number - Job Ex - 001. Under Name of Item, select the Finished Goods to be manufactured by the Job Worker. E.g. Cooker 12 Litre.
  2. In Stock Item Allocation screen
  3. Set Track Components to Yes
  4. Due On: In this specify the Date on which the delivery of Finished Goods is due. Example 6-1-2011
  5. Godown: In this field select the Godown where the finished goods will be stored on Receipt of the same from the job Worker. E.g. Finished Goods Location
  6. Quantity: Specify the Quantity of finished goods to be received from the Job Worker. E.g. 1000 U. Press enter from Quantity field to view Components Allocation screen
  7. In Components Allocation Screen, select the  Raw materials to be issued and Scrap to be received.
