Extracting Tally.ERP 9 Data in Excel Using ODBC
Using the Open Database Connectivity (ODBC) feature available in Tally.ERP 9, you can extract data to Excel, and generate the required reports.
To extract data from Tally.ERP 9 in Excel
1.     Open Excel on your local system.
2.     Click Data > Get External Data > From Other Sources > From Microsoft Query. The selection of From Microsoft Query in Excel appears as shown below:
3.     Select the data files in Choose Data Source screen. For example, TallyODBC 9000*.
Note: When the Data Source Name (DSN) selected is TallyODBC64_9000, 9000 is the ODBC server port number.
4.     Click OK. The Query Wizard - Choose Columns screen appears as shown below:
o      Select Ledger and expand the list to select the required fields.
5.     Click Next. The Query Wizard - Filter Data screen appears as shown below:
o      Select the data from Column to filter to included them in rows, as required.
6.     Click Next. The Query Wizard - Sort Order screen appears as shown below:
o      Select Ascending or Descending in the field Sort by, as required.
Note: Map the parent as Sundry Debtors or Sundry Creditor or both, as required.
7.     Click Next. The Query Wizard - Finish screen appears as shown below:
o      Select the option Return Data to Microsoft Office Excel.
o      Click Save Query. You can save the query in a selected path (for example, C:\Documents and Settings\User\Application Data\Microsoft\Queries\Query from TallyODBC_9000.dqy).
                                                             or
o      Click Finish. The Import Data screen appears as shown below:
8.     Press OK. The Excel sheet with the imported data appears as shown below:
See also
