Inserting and Renaming Heads in Schedule VI Balance Sheet
Tally.ERP 9 provides users with the option to rename and insert Heads in the Schedule-VI Balance Sheet as per their business needs.
Renaming Heads
To rename Schedule VI Heads,
Go to Gateway of Tally > Audit & Compliance > Financial Statements > Balance Sheet
The Change Display Name sub-screen appears:
The Schedule VI Head appears renamed in the Schedule-VI Balance Sheet:
Inserting Heads
Users can insert Heads at lowest level of the hierarchy of Schedule VI Heads.
For example, User will not be able to insert head at Current Assets (Schedule VI Head) level, but will be able to do it at Other Current Assets (Sub-head) level.
To insert a head in the Balance Sheet,
If, for instance, Interest Accrued on Investments has to be inserted under Other Current Assets,
A List of Heads appears:
The newly inserted Head (Interest Accrued on Investments) appears classified under the chosen Head (Other Current Assets)
Add New Head
Another way of inserting Heads is by using the I: New Head button.
The Create Schedule VI Head screen appears:
Note: Ctrl+I: Insert Head picks the Schedule VI Group based on the position of the cursor in the Balance Sheet. Users may press Backspace to change the Group.
I: New Head automatically displays the List of Heads for the user to choose from, irrespective of the position of the cursor in the Balance Sheet.
Deleting inserted Heads
To delete an inserted Head,
Note: Default Schedule VI Heads cannot be deleted. Also, Inserted Heads to which Tally Groups have been linked cannot be deleted.
