Using Multiple Addresses for Ledger Accounts
To create multiple addresses for a single ledger:
Note: The option Use Multiple Addresses can also be enabled from Gateway of Tally > F12: Configure > Accts / Inventory Info.
The filled Mailing Details screen appears as shown:
Use Multiple Addresses in Voucher / Invoice Entries
To opt for the required address type while passing transactions, follow the steps shown:
Example: Purchase Invoice.
Note: The Consignee details appear only when you have enabled the option Allow Separate Buyer and Consignee Names in F12: Configure.
Note: Similarly, you can select the Customer ledger and choose the required Address Type in the Sales Invoice and other required voucher types.
