Creating a Budget
To create a Budget in Tally.ERP 9
  1. Go to Gateway of Tally > Accounts Info > Budgets > Create.
  2. In the Budget Creation screen, enter a Name for your budget.
  3. Select a budget from the List of Budgets for Under field.
  4. If you want to set up a hierarchical structure for budgets:
Note: You can create more primary budgets if needed.
  1. Enter the period of the budget in the From and To fields. You can enter the period entered as a month, a year, or any other period.
  2. In Set/Alter Budgets of, select one of the following options:
• Groups - To create a budget for a Group of ledger accounts.
• Ledgers - To create a budget for Ledgers.
• Cost Centres - To create a budget for Cost Centres.
  1. Accept to save.
More:
