Licensing and Configuration for Multi Site
The Account/Site Administrator can configure or surrender a site belonging to an account. The configuration set can be created for each site by the Account/Site administrator. Further, the Account administrator can allow or restrain the site administrator or user from making any changes to the configuration set locally.
In the Control Centre screen under Licensing & Configuration,
Provide details for a site and change the status
The Licensing & Configuration screen appears as shown:
Note: By default, the Account Administrator is authorized to change the E-Mail ID of the Site Administrator.
Note: In case a site is not confirmed within 15 days from the date of activation, it will be treated as rejected.
    1. Pending for Confirmation: is displayed when the site is awaiting confirmation by the account administrator
    2. Reject: select this option to decline the validation of an activated site.
In case the Account Administrator rejects or declines the confirmation of a site, you can once again activate the site using the option Activation of an Additional Site for your organisation.
Similarly, the account administrator can provide the site details, change the E-Mail ID of the Site Administrator or change the status for other sites within the account.
The completed Licensing & Configuration screen will appear as shown:
Button options in Licensing & Configuration screen
F1: Detailed
Press Alt+F1 for a detailed view of the screen. This will display all details of the user that has been defined in Site Profile screen.
F3: Group By
Press F3 to group information based on the Product (Tally.ERP 9, Tally.Server 9, etc.) or Serial Number.
F6: Show Config
Press F6 to view the General Configuration and TDL Configuration set for the respective Site.
F12: Configuration
The following options can be used to configure Licensing & Configuration screen:
Note: 1. Only one F12: Configure option can be used at a time to configure the report.
        2. Once the Account administrator confirms the activation of a site, the status Active & Surrender are available.
        3.To reactivate a Site you have to follow the reactivation process discussed in Licensing.
To Create Configuration set for a Site
In the Licensing & Configuration screen
    1. Specify the required Server Name/ IP Address/URL in From field to deny a request from the Server/IP Address/URL.
    2. Similarly, specify the required Server Name/ IP Address/URL in To field to deny a request to Server/IP Address/URL
    1. Specify the required Server Name/ IP Address/URL in From field to allow a request from the Server/IP Address/URL.
    2. Similarly, specify the required Server Name/ IP Address/URL in To field to allow a request to Server/IP Address/URL.
TDL Configuration
The Completed Configuration package for respective serial number is appears as shown:
Note: When Tally.ERP 9 is started after including/updating the Accounts TDL under TDL Config, it will prompt with a message during heart beat 'Account TDLs are updated. Please restart your Tally.ERP 9 for the changes to take effect'. Restart Tally.ERP 9 for the effect to take place.
For an immediate effect of Accounts TDL, you may start Tally.ERP 9 and Update license.
To View/ Alter General Configuration
To View/ Alter TDL Configuration
The Licensing & Configuration screen also displays information on the following:
