Specifying Reorder Levels
Tally.ERP 9 allows you to specify Reorder levels and minimum Order Quantity for each stock item with simple and advanced parameters.
Specifying Simple Reorder Level and Minimum Order Quantity
Specifying Advanced Reorder Levels and Minimum Order Quantity
Note: The option Reorder Levels is displayed in the Inventory Info. menu only if Allow Purchase Order Processing is enabled in F11: Inventory Features.
