You can modify or delete a currency master using the Alter option. Rates of Exchange can also be altered from here.
To alter a currency master:
Go to Gateway of Tally > Accounts Info. > Currencies > Alter
Select a Currency from the Currencies list (displayed if there is more than 1 currency)
In the Currency Alteration screen, alter details as required. For more information refer Creating a Currency
The Currency Display screen displays the details and rates of exchange for a selected currency.
To display the Currency screen:
Go to Gateway of Tally > Accounts Info. > Currencies > Display
Select a Currency from Currencies list (displayed, if there is more than 1 currency)
Enter to view the details
To delete a Currency:
Select a currency from the Currencies list (displayed, if there is more than 1 currency)
Press Alt + D in the Currency Alteration screen to delete
Note: You cannot delete a Currency, if it is used in any transaction.
