Stock Items - Finished Goods
Finished Goods (Without BOM)
To create the stock item
Go to Gateway of Tally > Inventory Info. > Stock Item > Create
Note: ABC Company wants to track the cost of manufacture of Cooker 12Litre.
Stock Item - If Excise Applicable
Go to Gateway of Tally > Inventory Info. > Stock Items > Create
Finished Goods (with BOM)
For Stock Item - Cooker 10Litre Two Bill of Materials are used.
Tally.ERP 9 Release 3.0 allows to create multiple BOM for a stock item which can be used for material issue for production.
Note: A Bill of Materials is a list of constituent items along with quantity details that can be allocated for the manufacture of a certain product, by-product or Co-Product.
Setup:
In F12: Configure (Stock Item Configuration)
Setup:
In F12: Configure
Note: On enabling the configuration option Define Type of Component for BOM in Stock Item Components (BOM) screen a new column Type of Item will be displayed.
Note: Tally.ERP 9 displays 4 Type of Items for selection
* By-Product: Select this classification for the stock items which are produced as By-Product of finished goods.
* Component: Select this classification for the Raw materials /inputs which are used or consumed for the production of finished goods.
* Co-Product: Select this classification for the stock items which are produced as Co-product of finished goods
* Scrap: Select this classification for the stock item produced as scrap in the process of manufacture of finished goods.
If the Component Type selected is Co-product or By-Product or Scrap, cursor will move to Rate (%) column to define the percentage of cost of production of Co-product/By-Product or Scrap
The completed Stock Item Components (BOM) screen is displayed as shown
Observe to manufacture 1 Pressure Cooker, 5 different inputs are required and while manufacturing Aluminium scrap will be produced. The Quantity of inputs consumed to manufacturer finished goods is 1 each of 5 different inputs.
Note: ABC Company wants to track the cost of manufacture of Cooker 10Litre.
The completed Stock Item Creation screen is displayed as shown
