The Excise Voucher Type for Purchase, Sales and Debit Note has to be created before creating the invoices.
To create the Purchase Voucher Type,
Go to Gateway of Tally > Accounts Info. > Voucher Types > Create
Enter the name of the Voucher type in Name Field e.g. Excise - Purchases
Select Purchase as the voucher type in Type of Voucher Field
You may abbreviate the Voucher type as per your requirement e.g. Ex-Purc
Select the appropriate Method of Voucher Numbering e.g. Automatic
Set Use Advanced Configuration to Yes to specify the advanced settings for the numbering method selected, if required
Set Use for Excise to Yes to enter Excise Purchase to capture Assessable Value and Excise Duty breakup
In Default Excise Unit select ABC Company from the List of Excise Units
Set Print after saving Voucher to No
Press Enter to accept and save
Note: The Use for Excise option will appear in Purchase/Debit Note and Sales/Credit Note only and if the Excise feature is enabled in the F11 Feature > F3: Statutory & Taxation.
In case where a company has more than One Excise Unit, you have to create separate set of voucher types for each Excise Unit.
To create the Sales Voucher Type,
Enter the name of the Voucher type in Name Field. E.g. Excise - Sales
Select Sales as the voucher type in Type of Voucher Field
You may abbreviate the Voucher type as per your requirement. E.g. Ex- Sales
Set Print after saving Voucher to Yes
Enter the print title of the Voucher type in the Default Print Title field e.g. EXCISE INVOICE
Enter the Default Jurisdiction. E.g. Bangalore
Set Is Tax Invoice to No
Specify the Declaration, if any
In Excise Declaration field, the default declaration provided will be displayed. If required details of declaration can be changed
Note: In Excise Sales Voucher Type (during Creation & Alteration of voucher type) a new field Excise Declaration is provided in voucher type screen. This field is introduced in Release 3.0 & will display in Excise Sales & Excise Debit Note Voucher Types.
Press Enter to Accept and save
A Debit note Voucher type has to be created if a Debit Note has to be passed. The Voucher Type should be created under Debit Note Type of Voucher.
Enable Use for Excise and select ABC Company as the Default Excise Unit.
In Excise Declaration field, the default declaration provided will be displayed. If required details of declaration can be changed.
Note: In Excise Debit Note Voucher Type (during Creation & Alteration of voucher type) a new field Excise Declaration is provided in voucher type screen. This field is introduced in Release 3.0 & will display in Excise Sales & Excise Debit Note Voucher Types.
Manufacturing Journal is used to account the issue of raw materials to production floor and for the receipt of finished goods.
In Tally.ERP 9 user can create a Manufacturing Journal under Stock Journal or alter the exiting Stock Journal
Note: In this scenario we are altering the existing Stock journal to account the manufacture of Packed Drinking Water.
