Outward Connectivity from Tally.ERP 9
Using the ODBC feature available in Tally.ERP 9 the user can extract the necessary data in Excel and generate the required reports.
To extract data from Tally.ERP 9 in Excel execute the following steps:
The screen displayed above appears when Tally.ERP 9 exe is 32 Bit.
Note: If Tally.ERP 9 - 64 Bit, the screen appears as shown below: Observe that the DSN (Data Source Name) selected is TallyODBC64_9000, where 9000 is the ODBC Server port number.
Exceptional cases for 64 Bit compatible scenarios
There are three important elements whose bitness determine the Export via ODBC process:
The ODBC feature works seamlessly when, the Operating System, Tally.ERP 9 and MS Office are all 64-bit. The method for this is as shown above.
However, there is a driver requirement if, the Operating System is 64 Bit, while
As can be seen, in both cases there is a bitness mismatch between Tally.ERP 9 and MS Office. Due to this, Tally.ERP 9 (which acts as the ODBC Server) will not be able to communicate with MS Excel and hence data will not be exported.
Now, to enable data export, a driver is to be installed.
In the first scenario, to export data via ODBC,
In the second scenario,
To summarise,
Tally.ERP 9 Bitness
Operating System 64 Bit
MS Office 32 Bit
MS Office 64 Bit
32 Bit
Works seamlessly without driver installation
Driver to be Installed: tallywin64.dat
To install, select the tool regodbc64.exe and Run as Admin
64 Bit
Driver to be Installed: tallywin32.dat
To install, select the tool regodbc32.exe and Run as Admin
Once the driver has been installed, you can continue with the export process in MS Excel.
