You can generate the new format of irreversible TCPs in Tally.Developer 9 Release 5.4.
To generate the new format of irreversible TCPs
1. Load the Default TDL of Tally.ERP 9 Release 5.4 or higher.
2. Select Irreversible in the Compilation Formats section of the Project Properties screen.
