HomeDeveloper ReferenceTDL ReferenceMeasure the Performance of TDL
Explore Categories
 PDF
Measure the Performance of your TDL Code Snippet
Profiler is a very useful tool for programmers. TDL Profiler helps you to analyze and optimize your TDL code. The performance of the code snippet can be obtained using TDL profiler. The profiler provides information such as the time taken to evaluate a TDL artefact, the number of times the TDL artefact was executed and so on. The TDL artefact may be an expression, function, collection, remote call, a view change, or a Report/Form regeneration.
Profile an Operation
  1. Open TallyPrime in Developer mode.
  2. In the calculator panel, type the following commands.
Mode: Profile
Start
<Perform the operation which needs to be profiled>
Stop
Dump
Open
  1. The log file opens.
Note: The commands are case insensitive.
  1. The log file format is supported from Tally.ERP 9 Release 6.5.3 onwards.
The log file contains 3 sections:
Call Graph
This section details the order of execution of the TDL artefacts. In this section, a TDL artefact appears as many times as it was executed.
Column Title
Description
Exec. Order
This column gives the order in which the TDL artefacts were executed after the profiler started. In the image below, the TDL artefact MyLedgerentriesSummary was the first one to execute which in turn called the collection MyVouchersCollection , hence the order of execution was 1 and 2 respectively.
Depth
This number indicates the level at which the TDL artefact was executed within a hierarchy or a block of code. For example, in the image below, MyLedgerentriesSummary was executed at Level 0 followed by MyVouchersCollection at Level 1.
Total Time
The total time taken to execute the TDL artefact along with its children
Self Time
The time taken to execute the TDL artefact itself (excluding the time taken to execute its children).
Requestor Type/Requestor Name
The context in which the TDL artefact was executed. In the image below, the collection MyLedgerentriesSummary was invoked by the part DashBoardLedgerAmount and hence this is the Requestor for the TDL artefact MyLedgerentriesSummary .
TDL Artefact Type/TDL Artefact Name
The TDL artefact that is being profiled.
Result
This applies to only TDL expressions and contains the result of its evaluation.
Grouped by Parent Hierarchy
The data in this section is grouped based on the Parent Hierarchy. For example, if a TDL artefact appears more than once under a parent hierarchy, then the data of the TDL artefact is grouped.
The columns Depth, Requestor Type, Requestor Name, TDL Artefact type, TDL Artefact Name together uniquely identify a parent. Each subsequent depth represents a child of the current depth.
The count represents the number of times the TDL artefact was executed and Failed Count represents the number of times the TDL artefact failed during execution.
Grouped by TDL Artefacts
The data in this section is grouped by the TDL artefacts. Here each TDL artefact appears only once.
Profiler Commands
Commands
Description
Start
Start a new profiling session.
Stop
Stop data profiling
Reset
Discard the captured data.
Status
Check if the profiler is on/off
Dump
Dump the captured data to a log file excluding TDL artefacts which was executed in less than a millisecond.
Dumpz
Dump all the captured data irrespective of the time taken to execute.
Open
Open the last dumped log file within the current instance of Tally.ERP 9.
Detailed
This command toggles in-depth profiling on/off. By default, the detailed mode is off. When enabled, the profiler will also capture expression evaluations.
Post a Comment
Helpful?
