In-built Functions
In-built functions are functions predefined by the platform in order to accomplish a specific task. A wide range of functions are available in the TDL functions library for varied purposes like business-related, mathematical, string etc. The application developer has no control over the execution sequence of these functions. They can only be used as required to achieve their specific task. Some functions may not require any parameters like $$NewLine which moves to the next line. Some functions may require one or more parameters; depending on the design of the function. For example, $$Inwords accepts one parameter of the amount type and returns the amount in words.
Functions give the following benefits to the TDL programmer:
- Conditional execution/evaluation of statements
- Execution of a set of statements repeatedly, generally referred to as loops
- Defining variables and storing values from intermediate calculation/process
- Accepting parameters from the calling segment of code
- Working on data elements like getting an object from the calling context, defining the function execution context, looping on the objects of a collection, etc.
- Returning a ‘Value’ to the caller of the function
- Performing a set of actions sequentially/conditionally or repeatedly, without returning a value.
Note: To know more about in-built functions, refer to the function browser from TallyPrime Developer.
System Function: SysInfo
Use the function SysInfo to retrieve system-related information, like system date, operating system version, and so on. $$SysInfo accepts one parameter at a time, out of the 19 explained below.
Syntax
$$SysInfo : <Parameter>
where <parameter> is one of the values explained in the table below.
No. |
Parameter |
Description |
Example |
1 |
ApplicationPath |
The folder path where the current copy of Tally is running. |
C:/TallyPrime |
2 |
CurrentPath |
The data path configured in tally.ini, residing in the application path. |
C:/TallyPrime/Data |
3 |
SystemDate |
The system date. |
27-May-2017 |
4 |
SystemTime |
The system time. |
18:27 |
5 |
SystemTimeHMS |
The system time in hh:mm:ss format. |
18:27:36 |
6 |
SystemName |
The system name. |
TallyClient2 |
7 |
IsWindows |
Checks whether the system has Microsoft Windows operating system. |
Yes |
8 |
WindowsVersion |
The Microsoft Windows version with the build number. |
6.2 (9200) |
9 |
WindowsUser |
The name of the Windows user who has logged in. |
geetha.ram |
10 |
IPAddress |
The IP Address of the system. |
192.168.1.17 |
11 |
MACAddress |
The Media Access Control Address of the network adapter in the system. |
0720fhac027a |
12 |
RunningIPV4Addr |
The currently running Internet Protocol Version 4 address. |
192.168.1.17 |
13 |
RunningIPV6Addr |
The currently running Internet Protocol Version 6 address. |
2001:db8:85a3:8d3:1319:8a2e:370:7348 |
14 |
IsOSx64 |
Checks whether the operating system is 64-bit. |
Yes |
15 |
IsAdmin |
Checks whether the operating system is running in Admin mode. |
No |
16 |
TallyinAdminMode |
Checks whether TallyPrime is running in Admin mode. |
No |
17 |
UACStatus |
Checks whether the User Account Control is enabled. |
Yes |
18 |
SystemProxySettings |
The proxy settings in the system. |
192.168.1.17:8000 |
19 |
ModuleName |
The folder path and file name of the current application. |
C:/TallyPrime/tally.exe |
Function Enhancements in Tally.ERP 9 Releases
Release 1.5
New Functions
In this release, two new functions have been introduced – $$TgtObject and $$ContextKeyword.
Function – $$TgtObject
The new Context Evaluation function $$TgtObject evaluates the expression in the context of the Target Object. Using $$TgtObject, values can be fetched from the target object without making the target object as the context object.
Syntax
$$TgtObject : <String Expression>
Where,
<String Expression> is the expression which will be evaluated in the context of Target Object.
Usage of $$TgtObject in User Defined Functions
In a user-defined function, while setting the method values of the target object, the expression needs to be evaluated in the context of the target object itself. $$TgtObject is used in this case.
Example
Ledgers ‘Party 1’ and ‘Party 2’ are having some opening balance. The requirement is to add the opening balances of both ledgers and set the resultant value as the opening balance of Party 2.
[Function : Sample Function]
Object : Ledger : “Party 1”
00 : NEW OBJECT : Ledger : “Party 2”
01 : SET VALUE : OpeningBalance : $OpeningBalance + $$TgtObject:$OpeningBalance
02 : ACCEPT ALTER
;; By prefixing $$TgtObject to the opening balance, the closing balance of the Target Object, i.e., Party 2, is retrieved.
Here, ‘Party 1’ is the Source object and ‘Party 2’ is the Target object. The opening balance of ‘Party 2’ is accessed using the expression $$TgtObject:$OpeningBalance.
Usage of $$TgtObject in Collections
In simple collections, the source object and the target object are both the same. In the case of aggregate collections and user-defined functions, the target object is different.
The function $$TgtObject allows accessing the values from the target object itself, while the collection is being populated. It is required in the aggregate collection, where the source object is not the same as the target object.
The function $$TgtObject is useful when the values are to be populated in the collection, based on the values that have been computed earlier. In aggregate collections, the function $$TgtObject can be used in the attributes Fetch, Compute and Aggr Compute of collection.
Example:
A report is to be designed for displaying the stock item, the date on which the maximum quantity of the item is sold and the maximum amount is received. The collection is defined as follows:
[Collection : Src Voucher]
Type : Vouchers : VoucherType
ChildOf : $$VchTypeSales
[Collection : Summ Voucher]
Source Collection : Src Voucher
Walk : Inventory Entries
By : ItemName : $StockItemName
Aggr Compute : MaxDate : SUM : IF $$IsEmpty:$$TgtObject:$ItemDet OR + $$TgtObject:$ItemDet < $Amount THEN $Date + ELSE $$TgtObject:$MaxDate
Aggr Compute : ItemDet : MAX : $Amount
While creating a collection “Summ Voucher”, $$TgtObject is used to get the date on which the maximum sales amount is received for each stock item. $ItemDet gives the maximum amount received for the individual item. In the condition checking part, if the evaluated $ItemDet is empty for the stock item or is less than the current amount of the stock item of the source object, then the current date is selected, otherwise, the value of $MaxDate is retained.
Following Table shows the evaluation of values with respect to the target object:
Source Object |
Current Objects |
Target Objects |
3 Sales Voucher |
8 Inventory Entries |
3 |
Sales Voucher -1 Dated – 7/7/09 |
Item 1 – Rs.500 Item 2 – Rs.500 Item 3 – Rs.500 |
Item 1 – 7/7/09 – Rs 500 Item 2 – 9/7/09 – Rs 700 Item 3 – 8/7/09 – Rs 800 |
Sales Voucher -2 Dated – 8/7/09 |
Item 1 – Rs.400 Item 3 – Rs.800 |
Sales Voucher -3 Dated – 9/7/09 |
Item 1 – Rs.300 Item 2 – Rs.700 Item 3 – Rs.500 |
Function – $$ContextKeyword
A new function $$ContextKeyword can be used to get the title of the current Report or Menu. It is used to search the context-sensitive/online help based on the Report or Menu title.
Syntax
$$ContextKeyword [:Yes/No]
The default value is NO . If the value is specified as YES , then the title of the parent report is returned. If no report is active, then the parameter is ignored. If the attribute Title is not specified in the Report definition, then by default, it returns the name of the Report.
Example
[Report : Context Keyword Function]
Form : Context Keyword Function
Title : “New Function Context Keyword”
[Field : Context Keyword Function]
Use : Name Field
Set As : $$ContextKeyword
In this example, the functions return the Title of the current report, i.e., “New Function Context Keyword”. If the parameter value Yes is specified, then the title of the ‘Report’ from where the report “Context Keyword Function” is called, will be returned.
Release 1.52
New Functions
New functions $$AccessObj , $$FirstObj and $$LastObj have been introduced in this release.
Function – $$AccessObj
The capability to access data objects associated with Interface objects was introduced in Tally.ERP 9. The attribute ‘Access Name’ is used to specify name to ‘Part’ or ‘Line’ Definition. This name can be used to refer to the Data Object associated with the Part or the Line.
A new function $$AccessObj has been introduced to evaluate the specified formula in the context of the Interface object identified by the given definition type and access name.
Syntax
$$AccessObj : <Definition Type> : <AccessNameFormula> : <Evaluation Formula>
Where,
<Definition Type> can be Part or Line.
<Access Name Formula> can be any formula which evaluates to a string.
<Evaluation Formula> is a formula which is evaluated in the context of the object identified by the definition type and the access name.
Example
[Line : AccessObj]
Fields : AccessObj AccessName : “AO1”
On : Focus : Yes : CALL : AccessObj
[Field : AccessObj]
Set As : $Name
[Function : AccessObj]
Variable : AccessObj : String
00 : SET : AccessObj : $$AccessObj:Line:”AO1″:$Name
10 : LOG : ##AccessObj
The Line ‘AccessObj’ is identified by the access name ‘AO1’. The access name is used while evaluating the value of $Name.
Functions – $$FirstObj and $$LastObj
The objects of the collection are available in the context of repeat line or while performing a walk inside a function. The functions $$FirstObj and $$LastObj can be used to find the first or the last object of the collection respectively.
Function – $$FirstObj
The function $$FirstObj returns the value of the specified method for the first object of the collection.
Syntax
$$FirstObj : <MethodName>
Where,
<Method Name> is the name of a method of the current object in context.
Example
40 : LOG : “First Object : ” + $$FirstObj:$Name
$$FirstObj logs the name of the first object of the collection, which is used in Walk Collection.
Function – $$LastObj
The function $$LastObj returns the value of the specified method for the last object of the collection.
Syntax
$$LastObj : <MethodName>
Where,
Example
50 : LOG : “Last Object: ” + $$LastObj:$Name
The function $$LastObj logs the name of the last object of the collection, which is used in Walk Collection.
Release 3.6
Function – $$PrinterInfo
Function $$PrinterInfo has been introduced to extract the settings information for any installed printer. This function is very useful to get the information of the printer, based on which, we can determine the dimensions for pre-printed invoice, etc.
Syntax
$$PrinterInfo : <Printer Name> : <Information Type>
Where,
<Printer Name> refers to the name of the printer for which the information is required.
<Information Types> are permissible information types like PrintSizeinInches, LeftMarginInMMs, etc.
Example
$$PrinterInfo : HPLaserJet4250PCL6 : PrintSizeInInches
The list of permissible Information Types are:
- LeftMarginInMMs returns the Number which denotes the space to be left on the Left side of the page in Millimeters.
- TopMarginInMMs returns the Number which denotes the space to be left on the Top of the page in Millimeters.
- RightMarginInMMs returns the Number which denotes the space to be left on the Right side of the page in Millimeters.
- PrinterExists returns Logical value (YES/NO), indicating if the Printer Exists or not.
- PrintSizeInInches returns the dimensions which denotes the Print Area in Inches, i.e., excluding the Margins.
- PrintSizeInMMs returns the dimensions which denotes the Print Area in Millimeters, i.e., excluding the Margins.
- PrintSizeInLines returns the dimensions which denotes the Print Area in Lines, i.e., excluding the Margins.
- PaperSizeInInches returns the dimensions which denotes the Paper Size in Inches, which includes the Margins.
- PaperSizeInMMs returns the dimensions which denotes the Paper Size in Millimeters, which includes the Margins.
- PaperSizeInLines returns the dimensions which denotes the Paper Size in Lines, which includes the Margins.
- PaperType returns the selected Type of the Paper, e.g., A4, A5 Small, etc.
- PortName returns the Port Name configured for the Printer.
- Orientation returns the Orientation Type of Paper, i.e., Landscape or Portrait.
The following screen capture displays the selected Printer details for all the information types:
Function – $$IsInternetActive
$$IsInternetActive is a function which helps to determine if the Internet is currently active. It returns TRUE if the Internet is accessible, else returns FALSE. It can be used to perform conditional operations, i.e., based on the Internet Connectivity, certain actions can be triggered.
This function checks if the internet is active, such that the operations pertaining to connecting to web pages, emailing, uploading files to FTP, etc., can be performed.
Syntax
$$IsInternetActive
Example
[Function : EmailifConnected]
00 : IF : $$IsInternetActive
;; Function called to Email O/s Stmts
10 : Call : Email Outstanding Statements
20 : ENDIF
In this example, the Outstanding Statements are E-Mailed, if Internet connection is present.
Function – $$CaseConvert
Prior to this release, the function $$Upper has been used to convert the string expressions to upper case, but there were no functions available for other conversions like Lower case, Title Case, etc. To overcome the difficulty of converting the string to Lower case, Title case, etc., a new function $$CaseConvert has been introduced, to convert the case of the given expression to the specified case format. This function will return a string expression in the converted format.
This function is very useful when one needs to follow the case rules to display the Name of the company, Name of the bank, etc.
Syntax
$$CaseConvert : <CaseKeyword> : <Expression>
Where,
<CaseKeyword> can be All Capital, Upper Case, All Lower, Lower Case, Small Case, First Upper Case, Title Case, TitleCaseExact, Normal, Proper Case, etc.
- All Capital/Upper Case converts the input expression to upper case.
- All Lower/Lower Case/Small Case converts the input expression to lower case.
- First Upper Case converts the first letter of the first word in a sentence to upper case. Other characters will remain as they are.
- Title Case converts the input expression to Title case, i.e., the principal words should start with capital letters.
- It will not convert the prepositions, articles or conjunctions, unless one is the first word.
- It will ignore a subset of words from capitalization like the, an, and, at, by, to, in, of, for, on, cm, cms, mm, inch, inches, ft, x, dt, eis, dss, with, etc. For this subset of words, the original strings’ cases will be preserved.
- TitleCaseExact converts the input expression to Title case, i.e., the principal words will start with capital letters.
- It will ignore a subset of words from capitalization like the, an, and, at, by, to, in, of, for, on, cm, cms, mm, inch, inches, ft, x, dt, eis, dss, with, etc. This subset of words will be converted to small case.
- Proper Case converts the input expression to Title case, i.e., all the words in a sentence should start with capital letters.
- Normal preserves the input expression as it is.
<Expression> is any expression of type ‘String’.
Example: 1
To convert the expression to upper case:
[Field : String Convert]
Set as : $$CaseConvert:UpperCase:“Tally solutions Pvt. Ltd.”
In this example, the function returns “TALLY SOLUTIONS PVT. LTD.” in the field ‘String Convert’.
Example: 2
To convert the expression to Lower case:
Set as : $$CaseConvert:LowerCase:“Tally Solutions Pvt. Ltd.”
Here, the function returns, “tally solutions pvt. ltd.” in the field ‘String Convert’.
Example: 3
To convert the expression to Title Case:
[Field: String Convert]
Set as : $$CaseConvert:TitleCase:“To convert the striNg to Title case”
Here, the function returns “To Convert the String to Title Case” in the field ‘String Convert’.
Example: 4
To convert the expression to Title Case Exact:
Set as : $$CaseConvert:TitleCaseExact:“To convert the string to Title case”
Here, the function returns “ To Convert the String to Title Case” in the field ‘String Convert’.
Example: 5
To convert the expression to first upper case:
Set as : $$CaseConvert:FirstUpperCase:“Tally solutions pvt. ltd.”
Here, the function returns “Tally solutions pvt. ltd.” in the field ‘String Convert’.
Function – $$RandomNumber
A random number is a number generated by a process whose outcome is unpredictable, and which cannot be subsequently reliably reproduced. In other words, Random numbers are numbers that occur in a sequence such that, the values are uniformly distributed over a defined interval and it is impossible to predict future values based on past or present ones.
In this release, a new TDL function $$RandomNumber has been introduced to generate Random Numbers. In case of auditing, this can be useful for auditors who would like to pick up some vouchers randomly for authentication.
Syntax
$$RandomNumber[:<MinRange>[:<MaxRange>]]
Where,
<Min Range> and <Max Range> are optional. In the absence of Max Range, Long Max is considered, i.e., (2^31) – 1 = 2147483647. In the absence of Min Range, ZERO(0) is considered.
We can generate random numbers in different ways:
No Parameters: Don’t pass any parameters, i.e., just invoke $$ RandomNumber . Default values are assumed.
Only with the MinRange Parameter: Here, there is no need of passing Max range. In this scenario, Random number is generated from the given Min Range.
Both MaxRange and MinRange as Parameter: In this scenario, random numbers are generated for given range.
Example: 1
With no Parameters
Set As : $$RandomNumber
This code will return a Random Number between 0 and 2147483647.
Example: 2
With MinRange Parameter only
Set As : $$RandomNumber:9999
This code returns Random Numbers between 9999 and 2147483647, the random number being greater than or equal to 9999. Here, value of MinRange is 9999 and MaxRange is 2147483647.
Example: 3
With both Parameters (MinRange and MaxRange)
Set As : $$RandomNumber:9:9999
This code returns Random Numbers between 9 and 9999.
Release 3.61
Function – $$FileRead Raw
We have a function $$FileRead to read the contents from a text file, which was designed to ignore quotes, comments, spaces, etc., while reading the entire line. Now, a new function $$FileReadRaw has been introduced, similar to the Function $$FileRead, except that the Function $$FileReadRaw can read lines with:
- Quotes
- Comment characters (; /* */)
- Spaces & Tabs
Syntax
$$FileReadRaw[:<Number>]
Where,
<Number> denotes the number of characters to be read.
Example
[Function : Test FileReadRaw]
Variable : GetPath : String
Variable : Get_DownLoad_FileLine : String
000 : Set : GetPath : “C:\TextSource.txt”
010 : Open File : ##GetPath : Text : Read
020 : While : (TRUE)
030 : Set : Get_DownLoad_FileLine : $$FileReadRaw
Using this function, we can read lines with quotes, comment characters, spaces, tabs, etc. If $$FileReadRaw is specified with a parameter, the behaviour is the same as that of Function $$FileRead. If specified without parameters, the entire line is read without ignoring quotes, spaces, etc.
Function – $$IsAccountingVch
This function checks if the specified voucher type is Accounting Voucher or not. It returns a logical value.
Syntax
$$IsAccountingVch : <VoucherTypeName>
Where,
<VoucherTypeName> is the name of the voucher type.
Example
Set As : $$IsAccountingVch:##TSPLSmp_Information
Function – $$IsInvVch
This function checks if the specified voucher type is Inventory voucher or not (excluding Order vouchers). It returns a logical value.
Syntax
$$IsInvVch : <VoucherTypeName>
Where,
Example
Set As : $$IsInvVch:##TSPLSmp_Information
Function – $$IsPayrollVch
This function is used to check if the specified voucher type is Payroll Voucher or not. It returns a logical value.
Syntax
$$IsPayrollVch : <VoucherTypeName>
Where,
<VoucherTypeName> is the n a me of the vouc h er type.
Example
Set As : $$IsPayrollVch:##TSPLSmp_Information
Function – $$IsOrderVch
This function is used to check if the specified voucher type is Order Voucher or not. It returns a logical value.
Syntax
$$IsOrderVch : <VoucherTypeName>
Where,
Example
Set As : $$IsOrderVch:##TSPLSmp_Information
Function – $$IsProdTallyServer
This function is used to check whether the product is Tally.Server 9 or not. It returns TRUE if the product is Tally.Server 9.
Syntax
$$IsProdTallyServer
Example
[Function : TSPL Smp IsProdTallyServer]
00 : If : $$IsProdTallyServer
10 : Msg Box : “Server Check” : “The Current Productn is Tally Server”
20 : ELSE
30 : MSGBOX : “Server Check” : “The Current Productn is not Tally Server”
40 : ENDIF
Function – $$ExcelInfo
This function is used to get the Excel ‘version’ and to check whether ‘XLSX’ format is supported.
Syntax
$$ExcelInfo : <Keyword>
Where,
<Keyword> can be IsXLSXSupported or Version. The keyword IsXLSXSupported returns TRUE, if the format “xlsx” is supported, while Version returns the Excel version number.
Example
Set As : $$ExcelInfo:IsXLSXSupported
Function – $$IsServiceRunning
This function is used to check if the specified service is running or not. It returns TRUE if the service is running.
Syntax
$$IsServiceRunning : <Service Name>
Where,
<Service Name> can be any expression which evaluates to the name of the service.
Example
[Function : TSPL Smp IsServiceRunning]
00 : If : $$IsServiceRunning:”Tally.Server 9″
10 : MSG Box : “Service Check” : “The Current Service n is Running”
20 : ELSE
30 : MSGBOX : “Service Check ” : “The Current Service n is not Running”
40 : ENDIF
Function – $$IsServiceInstalled
This function is used to check if the specified service is installed on the system or not. It returns TRUE if the service is installed.
Syntax
$$IsServiceInstalled : <Service Name>
Where,
<Service Name> can be any expression, which evaluates to the name of the service.
Example
00 : If : $$IsServiceInstalled:”AppMgmt”
10 : Msg Box : “Service Check” : “The Current Service n is installed”
20 : ELSE
30 : MSGBOX : “Service Check” : “The Current Service n is not Installed”
40 : ENDIF
Function – $$ReadINI
The function is used to read the INI file, and get the value of any parameter in the INI.
Syntax
$$ReadINI : <PathFile Name> : <Section Name> : <Parameter> [: <Index>]
Where,
<PathFile Name> is the filename of the INI file, along with the path.
<Section Name> is the section name in the INI file.
<Parameter> is the Parameter whose value is to be fetched from the INI.
<Index> is an optional parameter. It can be used when multiple values for the same parameter are accepted.
Example
Set As : $$ReadINI:“C:\Tally.ERP9\tally.ini”:”TALLY”:”User TDL”
Function – $$IsUserAllowed
This function verifies and returns TRUE if user is allowed to perform the specified operation on current Tally.Server9.
Syntax
$$IsUserAllowed : <Username> : <Operation> : <Tally Server Name>
Where,
<User Name> is the name of the user.
<Operation> is the operation that the user wants to perform. This can be any one of BackUp, Restore, Rewrite, Create Company, Split Company and Monitor Tool.
<Tally Server Name> is the name of the Tally.Server 9
Example
Set as : $$IsUserAllowed:$User_name1:”Restore”:##SvTallyServer
Function – $$IsTSAuthorised
This function checks if security is enabled on the specified Tally.Server 9. It returns TRUE if security is enabled, else it returns FALSE.
Syntax
$$IsTSAuthorised : <TallyServer Name>
Where,
<Tally Server Name> is the name of the Tally.Server 9.
Example
[Function : TSPL Smp IsTSAuthorised]
00 : If : $$IsTSAuthorised:##SvTallyServer
10 : MSG Box : “Security Check” : “Security Control is Enabled”
20 : ELSE
30 : MSGBOX : “Secuirity Check ” : “Security Control n is not Enabled”
40 : ENDIF
Function – $$TSPingInfo
This function is used to retrieve the information related to Tally.Server 9 like License mode, Number of license subscription days left, etc.
Syntax
$$TSPingInfo : <TallyServer> : <Keyword>
Where,
<Tally Server Name> is the name of the Tally Server.
<Keyword> can be any one of the keywords – Iseducational, LicenseExpiryDaysLeft and HasINFO.
- HasINFO returns TRUE or FALSE depending on whether the client is able to get information for this Tally.Server 9 (otherwise Iseducational and LicenseExpiryDaysLeft fail in a TDL expression).
- IsEducational returns TRUE if the Tally.Server 9 is running in Educational mode.
- LicenseExpiryDaysLeft returns the number of subscription days remaining.
Example
Set As : $$TSPingInfo:##SvTallyServer:##Ping_Operation
Function – $$IsTSCompany
This function checks whether the current company is opened through Tally.Server 9 or not. It returns a logical value.
Syntax
$$IsTSCompany : <Company Name>
Where,
<Company Name> is the name of the company.
Example
Set As : $$IsTSCompany:$CompanyStorage
Function – $$SelectedNonTSCmps
This function returns the total number of companies which are not loaded via Tally server, i.e., companies from local or shared data folders.
Syntax
$$SelectedNonTsCmps
Example
00 : If : $$SelectedNonTsCmps
10 : Msg Box : “Company Check” : $$SelectedNonTSCmps + “Total Companies not loaded via Tally server is \n”
20 : ELSE
30 : MSGBOX : ” Company Check ” : “All Companies Have been Opened Via Tally Server “
40 : ENDIF
Function – $$IsTSPath
This function checks whether the given path is Tally.Server path or not.
Syntax
$$IsTSPath : <Path>
Where,
<Path> is any expression, which evaluates to a Tally Server Name or a Data Location Name.
Example
Set As : $$IsTSPath:”Data1:”
Release 4.8
Function – $$IsTDLLoaded
A new function ‘IsTDLLoaded’ has been introduced to check if a particular TDL is already loaded. This function returns TRUE if the particular TDL/TCP file is already loaded, and FALSE if it is not.
Based on the result of this function, further actions like Loading and Unloading of TDL, or executing a Report from the dynamically loaded TDL File, etc., can be performed.
Syntax
$$IsTDLLoaded : <TDL/TCP File Path Expression or GUID Expression>
Where,
< TDL/TCP File Path Expression or GUID Expression > evaluates to the path of the TDL/TCP File or GUID of the TCP File to be checked, whether it is loaded or not.
Example
[Function : Display First TDL Report]
00 : If : $$IsTDLLoaded:@@TCPFileGUID
10 : Display : First TDL Report
20 : Unload TDL : @@TCPFileGUID
30 : End If
[System : Formula]
TCPFileGUID : “c2901088-349b-434b-946c-9ada601fd6b7”
In this example, if the TDL with GUID “c2901088-349b-434b-946c-9ada601fd6b7” is loaded, then the Report ‘First TDL Report’ will get displayed. Subsequently, the TDL is unloaded.
Function – $$HttpInfo
It is used to get the details of URL Host, ContentLength and Header information available during the receiving of the SOAP request. It accepts two parameters – ‘InfoType’ and ‘Info Sub Type’.
Function – $$ImportType
The Function $$ImportType is used to determine the type of Import, i.e., the source of data. The possible Import Types could be ‘Sync’, ‘Migration’, ‘Remote’, ‘NatLang’, ‘SOAP’ or ‘Manual’.
Function – $$ImportAction
This function is used to indicate the status of Import, i.e., whether the current Object was Created, Altered, etc. The possible results are ‘Created’, ‘Altered’, ‘Ignored’, ‘Combined’, and ‘Error’.
Function – $$LastImportError
The Function $$LastImportError can be used to extract the Import error description for the last object imported, which is helpful to retrieve after every import, and appropriate error logs can be maintained and displayed at the end of the Import Process. In case there is no Error while Importing the current Object, it would return the value as ‘Empty’.
Function – $$ImportInfo
The Function $$ImportInfo is useful to extract the details of the Imported Objects in terms of Number of Objects Created, Altered, Ignored, Combined, etc., and Errors encountered. This Function accepts a parameter ‘InfoType’.
Note: For details of the functions $$HttpInfo, $$ ImportType , $$ImportAction , $$LastImportError and $$ImportInfo , refer to the section ‘Data Importing Enhancements’.
Release 5.4.8
Function – IsAnyEmpty
When you want to check if there is an expression that evaluates to empty among a set of expressions, you can use the function IsAnyEmpty. This function evaluates the expression parameters in the sequence specified in the code. It will return True, the moment an expression evaluates to empty and ignores the subsequent expressions.
Syntax
$$IsAnyEmpty:<Expression1>:<Expression2>:…..:<ExpressionN>
Where,
Expressions can be variables, formulae, functions, etc.
Example
[Collection: TNOldAnnexIASummaryWithoutError]
Compute Var : HasError : Logical :$$IsAnyEmpty:##svRefNo:##svRefDate:##svLorryDate
Ensure that the sequence of parameters is such that higher the probability of an expression being Empty, earlier in the order they should be placed.
Previously, to evaluate more than one expression for empty, you had to use $$IsEmpty along with OR operator. Now, you can just use the new function to evaluate multiple expression in a single line.
Release 5.4.9
Function – ValidateTINMod97
You can use the function ValidateTINMod97 to check if the TIN provided is valid or not. It takes an input string which is the TIN and returns a logical value. It returns True if the input string is a valid TIN.
To check if the given string is a valid TIN, the function performs the following:
- Extract the digits from the alphanumeric string and check if there are exactly 11 digits.
- Rotate the number clockwise 4 times, perform MOD operation on the resulting number with 97, and check if the remainder is 1.
The TIN is not valid if any of the above checks fail.
Syntax
$$ValidateTINMod97:<Alphanumeric Value>
Where,
<Alphanumeric Value> is the TIN having alphabets as prefix/suffix.
Example
[Field: Mod 97]
Use : Name Field
Set as : 27240039198
Notify : IsValidTIN : Yes
[System: Formulae]
ValidateTin : $$ValidateTINMod97:$$Value
IsValidTIN : If @@ValidateTIN then “Valid” Else “NOT Valid”
Release 5.5.2
Function – SysInfo
The function SysInfo is enhanced to get the file name of the current application with the folder path.
Example
$$SysInfo:ModuleName
If the application path is C:\TallyPrime , it returns C:\TallyPrime\tally.exe .
