TallyPrime Release 6.0 Beta is now live! Click here to learn more & get early access to the Power Banking experience! You also get smoother Data Split with robust verification. Easily manage contact details with the new Profile.
https://help.tallysolutions.com/docs/te9rel65/Tax_International/GCC_VAT/stock_masters_for_gcc_vat.htm
Stock Items and Stock Groups for GCC VAT
Related topics
Service Ledgers
Sales of Items
Purchase of Items
If the items that you sell have different tax rates, update your stock items with the applicable GCC VAT rates, and select the type of supply, as applicable. In case you need the same tax rate for the items in a stock group, modify the group to include tax applicability and rate.
Update stock items
Update stock groups
Update stock items
1. Go to Gateway of Tally > Inventory Info. > Stock Items > Alter > select the item.
2. Select the Taxability of the item.
o Taxable - for goods and services that are classified as taxable
o Exempt - for goods and services that are exempted from tax
o Zero Rated - for goods and services that have 0% tax
3. Specify the Tax rate .
Note: If you have modified the tax rates before, press Alt + L to view the history of tax rate changes.
4. Select the Type of supply . For stock items, Type of supply is set to Goods by default.
5. Press Ctrl + A to save.
The type of supply selected for a stock item is applicable only for that item.
You can record sales of stock items and print tax invoices.
Update stock groups
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Alter > select the group.
2. Enable S et/alter VAT details? to specify the details in the VAT Details screen, and save.
3. Press Ctrl + A to accept.
