Warning: Undefined array key 0 in /var/www/html/tallyweb/modules/pss/crm/kb/search/CKBTallyHelpSearchWIC.php on line 958
Warning: Undefined array key 1 in /var/www/html/tallyweb/modules/pss/crm/kb/search/CKBTallyHelpSearchWI.php on line 1203
Warning: Trying to access array offset on value of type null in /var/www/html/tallyweb/modules/pss/crm/kb/search/CKBTallyHelpSearchWI.php on line 1203
Backup & Restore - FAQ
https://help.tallysolutions.com/docs/faqs/faq/faq-backup-restore.htm
Some of the commonly asked questions about backup and restore are answered here.
1. How to auto back up your data using Cobian Backup?
2. While taking a backup of the company data we noticed that the auto backup file (ABK.900) of the respective company is excluded from the backup process. It is possible to include this file in the backup process?
3. What is the difference between the auto backup utility available in Tally.ERP 9 and the customized auto backup available?
4. Back Up of Tally Vaulted Companies
5. Where is the data backup stored when auto backup is enabled?
6. Insert Disk 2 in drive disk 2 is damaged
7. Function backupcmp label 02 action execution failed
8. What are the general differences between AutoBackup and Normal Backup?
9. Creating Backup in Folder Format
10. Can we take auto backup of multiple companies?
11. Unable to Create Backup
12. Where is the auto backup file of multiple companies stored?
13. Cannot backup
14. Could not restore 10000, while restoring TBK.900 file in Tally.ERP 9
15. While restoring data from back up the error File doesn't exists appears
16. Restoring a Deleted Company
17. Overwrite the Information message appears while restoring a backup data. Why?
18. Company is not displayed after restoring backup
