https://help.tallysolutions.com/docs/te9rel65/Voucher_Entry/Order_Processing/Viewing_Order_Position.htm
Viewing Order Position in Stock Summary Report
Stock Summary report can be viewed by adding columns or
To view the order position in stock summary,
1. Go to Gateway of Tally > Stock Summary .
2. Press Alt + F1 (For detailed view).
3. Press Alt + N > Select Orders & Stock Details .
Orders & Stock Details screen is displayed as shown:
Or
In the Stock Summary screen, you can add a new column using Alt + C .
Sales Order Reports can be accessed through Alt+F7 or Alt+C of the Stock Summary.
Viewing Purchase or Sales Order Outstanding
To view purchase or sales order outstanding,
Go to Gateway of Tally > Stock Summary > Press F9 > select Purchase or Sales Order.
Note: Inventory Reports and Accounting Reports can also be accessed through ALL other reports by pressing F9 or F10 (Accounting/ Inventory Reports) .
