https://help.tallysolutions.com/docs/te9rel66/Tax_India/excise-dealer/ed-group.htm
Creating Stock Group (Excise for Dealer)
You can create a stock group enabled for dealer excise by entering the relevant details.
To create a stock group
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Create .
2. Enter the Name of the stock group.
3. Set the option Set/Alter VAT Details to Yes/ No as per requirement. Click here to view the detailed procedure of defining VAT details in stock group.
4. Set the option Set/Alter Excise Details to Yes .
5. Provide relevant details in Excise Details screen.
6. Accept the Stock Group Creation screen.
