https://help.tallysolutions.com/docs/te9rel65/TSS/Connect_Company_on_TallyNET.htm
Connecting Company to Tally.NET Server
You need to connect your company data to the Tally.NET server for Tally.NET users and auditors to access and work on data remotely.
1. Go to Gateway of Tally .
2. Click F4: Connect . The Connect Companies to Tally.NET Server screen is displayed.
3. Select the required companies from the List of Companies .
4. Press Enter to connect the selected company to Tally.NET Server.
Note:
Changes made to the name of the Contact Person or the Contact Number will not be stored in the company masters.
The same steps can be followed for audit and synchronization purposes.
See Also
Creating Tally.NET user
Authorizing Tally.NET user
Setting up the remote login
