https://help.tallysolutions.com/docs/te9rel65/Creating_Masters/Accounts_Info/creating_a_single_group.htm
Creating a Single Group
You can create a single group in Tally.ERP 9 and configure its details as per your requirement. You can also view, alter or delete single groups that you have created.
Creating a Group
To create a single group
1. Go to Gateway of Tally > Accounts Info. > Groups .
2. Click the option Create under Single Group . The Group Creation screen appears.
3. Enter the Name of the group.
4. Enter the Alias name, if required.
5. In the field Under , from the List of Groups displayed, select the parent group under which the group has to be classified. For example, Indirect Expenses .
Note: Groups can be created under the group Primary , if required. To classify a group under Primary , the option Allow Advanced entries in Masters should be enabled in the Master Configuration screen .
The Group Creation screen appears as shown below:
6. Click Yes to accept the screen.
A group can be created for advanced usage, with more options to configure, by setting the option Allow Advanced Entries in Masters in F12: Configure.
Displaying a Group
To display a group
2. Click the option Display under Single Group .
3. Select the name of the group required from the List of Groups displayed. The ledger display screen appears as shown below:
Note: In the display mode , group details can't be modified.
Altering a Group
The details entered in a group can be modified when required.
To alter a group
2. Click Alter under Single Group .
4. Make the necessary changes in the Group Alteration screen.
5. Click Yes to save the changes.
Deleting a Group
Groups can be deleted from the alteration screen. Only one group can be deleted at a time.
To delete a group
2. Click the option Alter under Single Group .
4. Click D : Delete .
5. Click Yes to confirm deletion.
Note: A group cannot be deleted if:
The group has sub-groups.
The group has ledgers classified under it.
The group is a predefined master.
