https://help.tallysolutions.com/docs/te9rel66/Control_Centre/My_TallyNET_Account_Single_Site.htm
My Tally.NET Account for Single or Multi Site
My Tally.NET Accounts displays the User ID against the Tally.NET ID field, the Account ID , Security Level , permission to access Tally.NET Server , Site ID (for Multi Site only), permission to Administer the Account and the account Status . It also displays the Account IDs that are associated with your Account , based on your requirement you may disassociate your Account ID .
On selecting My Tally.NET Accounts , the My Tally.NET Accounts screen appears as shown:
Select the required Single Site Account ID or Multi Site Account ID and press Enter .
Note: Site ID will not appear when you have a Single Site Account .
To disassociate from another account, select the required Account ID and press Alt+D .
The Account/Site Administrator ID cannot be disassociated from associated accounts.
