https://help.tallysolutions.com/docs/te9rel65/Auditor_Edition/India/Statutory_Audit/Inserting_and_Renaming_of_Heads.htm
Inserting and Renaming of Heads (India)
Tally.ERP 9 provides users with the option to rename and insert Heads in the Schedule-VI Profit and Loss A/c as per their business needs.
The procedure for Renaming, Inserting, and deleting Inserted Heads in the Schedule-VI Profit and Loss A/c is the same as the procedure to do the same in the Schedule-VI Balance Sheet
Rename Heads
Insert Heads
Add New Head
Delete Inserted Heads
