https://help.tallysolutions.com/docs/te9rel65/Advanced_Features/Advanced_Inventory_Features/Reorder_Status_and_Quantities_to_Order.htm
Reorder Status and Quantities to Order
The Reorder Status report is a group-wise summary of the availability status of stock items. This report give us the number of purchase orders pending, sales orders pending, sales orders due, and thereby the nett availability of the stock item.  You can view the reorder level, the short fall in the stock item (calculated based on the nett available stock and reorder Level) , if any, and the minimum order quantity. This report will help you decide the quantity of the stock item  to be ordered based on the orders to be delivered, and stock-in-hand.
1. Go to Gateway of Tally > Display > Statements of Inventory > Reorder Status .
2. Select a Group .
The Inventory Reorder Status report appears as shown below:
Note: Click A : Reorder Only to remove items for which there are no orders to be placed.
