https://help.tallysolutions.com/docs/te9rel65/Advanced_Features/Advanced_Inventory_Features/Enabling_Item_Cost_Tracking.htm
Enabling Item Cost Tracking
Item Cost Tracking can be enabled from the Inventory Features screen. On enabling item costing for the company, the option Enable Cost Tracking? is available in ledger masters.
1. Go to Gateway of Tally > F11: Features (F2: Inventory Features)
2. Set Use cost tracking for stock item to Yes .
3. Press Ctrl+A to save the settings.
