https://help.tallysolutions.com/docs/td9rel54/tdl_reference/release_5_5_2.htm
What’s New in Release 5.5.2
Action - Browse URL
Attribute - SysInfo
Attribute – Data Source
This page includes information on all the important TDL improvements made in Tally.ERP 9 Release 5.5.2.
Language Enhancements in Procedures (TDL)
Action – Browse URL
The action Browse URL is enhanced to accept a logical value as an optional fourth parameter to open the URL in Admin mode.
Syntax
Action: Browse URL: <URL Formula>: [<Command Line Parameters>:<Logical Expression1>: <Logical Expression2>]
Where,
< URL Formula > is an expression which evaluates to a link to a website or a folder path.
< Command Line Parameters > is the list of command line parameters separated by space. It is an optional parameter.
< Logical Expression1 > can be any expression which evaluates to a logical value. When this parameter is set to yes, it executes the given action in hidden mode. It is an optional parameter.
< Logical Expression2 > can be any expression which evaluates to a logical value. When this parameter is set to yes, it executes the action in admin mode. It is an optional parameter.
Function – SysInfo
The function SysInfo is enhanced to get the file name of the current application with the folder path.
Example
$$SysInfo:ModuleName
If the application path is C:\Tally.ERP 9 , it returns C:\Tally.ERP 9\tally.exe .
The collection attribute Data Source is used to populate data to a collection dynamically from a variety of data sources. This attribute accepts the Type and Identity of the data source from where the data is to be retrieved. Directory , File XML , Name Set, and so on, are some of the data sources supported in TDL.
The collection attribute Data Source is enhanced to support Rule Set , Num Set , and Flag Set as new data source types. This attribute helps the developer to gather the data pertaining to Rule Set , Num Set , or Flag Set like other data source types. The information of Num Set and Flag Set give same results except for the value. The value of Num Set is a number and value of Flag Set is logical. These data sources can be used for generating reports using Value and User Description methods. Otherwise these can act as a debugging aid for the developer.
Syntax
[Collection: <Collection Name>]
Data Source: <Type>: <Identity>
Where,
<Collection Name> is the name of the collection where the data is populated.
<Type> specifies the type of data source. This enhancement includes Rule Set , Num Set and Flag Set as data source types.
<Identity> is the name of the Rule Set/Num Set/Flag Set. It can be an expression which results to the name of Num Set/Flag Set as specified in the corresponding data type.
Example
[Collection: DataSourceFSRepo]
Data Source: Flag Set: #FSDSVariable
The above code snippet helps to populate the collection DataSourceFSRepo with the data from the variable FSDSVariable , which returns a Flag Set name.
Data Source Type
Keyword
Parameters
Example
Rule Set
Rule Set
Name of the Rule Set definition
[Collection: DSRepo]
Data Source: Rule Set: DSRuleSet
Flag Set
Flag Set
Expression evaluating to the value of Flag Set data type
Data Source: Flag Set: $FlagSetValue
OR
Data Source:Flag Set: ##FlagSetValue
Num Set
Num Set
Expression evaluating to the value of Num Set data type
Data Source: Num Set: $NumSetValue OR
Data Source:Num Set:##NumSetValue
You can refer the below table to know more about this enhancement:
The list of methods used in Rule Set / Flag Set / Num Set as data source is listed below:
Method Name
Description
Method Value - Sample
Name
Rule Name which includes the complete doted notation
IsOpBalGT1000.IsPANEmpty.IsContactEmpty
Additional Name/Formal Name
Leaf Rule Name
IsContactEmpty
Parent
Current Rule Set Name
Dimension2
Value
Value for individual flag or number i.e., Logical for Flag Set and Number for Num Set. It is not applicable for Rule Set.
Logical - Yes
Number - 1
Sort Position
Index of the flag or number within the Flag Set and Num Set
5
Is Aggregate
IsAggregate flag for Rule Set, Num Set and Flag Set
No
Depth
Level or Depth of Rule Set, Num Set and Flag Set
3
User Description
Rule Set, Num Set and Flag Set description from corresponding Name Set
IsPartyContactEmpty
