https://help.tallysolutions.com/docs/td9rel54/tdl_reference/release_5_3_8.htm
What’s New in Release 5.3.8
Action - Format Excel Sheet
As we are aware, File Input/Output capability is used to support read/write operations in an Excel or Text file.
Currently, if we write any value to an excel file using File I/O approach, the appropriate column has to be adjusted manually based on the cell width after completion of the task. Now, a new capability is introduced to update the Cell Properties, Width and Text Wrap.
These properties can be set in TDL using the action, Format Excel Sheet.
Action – Format Excel Sheet
Action Format Excel Sheet is used to set the cell properties of Excel sheet. It accepts two parameters.
Syntax
Format Excel Sheet : <PropertyName> : <PropertyParms>
where,
< PropertyName > is a system keyword for an Excel cell property, viz.,ColumnWidth or CellTextWrap.
< PropertyParms > is a list of required parameters for the specified PropertyName and the number of parameters vary based on the PropertyName.
Example
[Function: FileIOExcel]
Variable : InputFile : String : "D:\SampExcel.xls”
010 : Open File: ##InputFile : Excel : Write
020 : Format Excel Sheet: CellTextWrap : 5 : 6 : Yes
030 : Format Excel Sheet: ColumnWidth: 1 : 30
040 : Close Target File
In the above example, CellTextWrap is the PropertyName and “5: 6: Yes” is the parameter required for the CellTextWrap property.
Supported Properties
ColumnWidth
Syntax
ColumnWidth: <ColumnNumber> : <Width>
where,
< ColumnNumber > is used to specify the column number whose width is to be modified.
< Width > is the number used to set the new width of the column. Unit of measurement used for this parameter is Points.
CellTextWrap
Syntax
CellTextWrap:<RowNumber>:<ColumnNumber>[:<Enablewrapping>]
where,
< RowNumber > is used to specify the row number of the cell.
< ColumnNumber > is used to specify the column number of the cell.
< Enablewrapping > is an optional parameter which specifies whether to wrap the text or not. The default value of this parameter is Yes.
Note: An expression can also be specified in any of the parameters for the action.
