https://help.tallysolutions.com/docs/td9rel54/tdl_reference/release_4_61.htm
What’s New in Release 4.61
COM Data Types Support
In Release 4.6, a new Definition Type COM Interface, a new Action Exec COM Interface, and new Functions $$COMExecute and $$IsCOMInterfaceInvokable had been introduced to extend Support for COM Servers. However, this support was limited to only a few COM Data Types.
From Release 4.61 onwards, the following COM Data Types will also be supported:
COM Data Type
TDL Data Type
Other Permissible TDL Data Types
Range of Values/Other Details
String
String
Number, Date,
Logical, Amount
Float
Number
String, Amount
3.4 * 10^-38 to 3.4 * 10^38
Double/Number
Number
String, Amount
1.7 * 10^-308 to 1.7 * 10^308
Currency/Amount
Amount
String, Number
This would have a precision of 4 decimal places, rather than 5, as in Tally.ERP 9. If Tally sends the number in 5 decimal places, DLL will round it off to 4 decimal places.
Char
String(1st character of String is used)
Number, Date, Logical, Amount (Only the First letter) For e.g., if the number is 987, then the result char would be 9 and similarly, for the other data types. For Date, it depends on the Date Format.
Single Character
Byte/Unsigned char
Number
String, Amount
0 to 255
Short/Wchar
Number
String, Amount
-32,768 to 32,767
Unsigned short
Number
String, Amount
0 to 65,535
Long
Number
String, Amount
-2,147,483,648 to 2,147,483,647
Long Long
Number
String, Amount
-9,223,372,036,854,775,808 to 9,223,372,036,854,775,807
Unsigned Long
Number
String, Amount
0 to 4,294,967,295
Unsigned Long Long
Number
String, Amount
0 to 18,446,744,073,709,551,615
Integer
Number
String, Amount
Unsigned Integer
Number
String, Amount
0 to 4,294,967,295
Bool/Boolean/ Logical
Logical
String (Yes/No, 0/1, True/False)
True/False
Date
Date
String
Variant
String, Number, Date, Logical, Amount
This can be an Out or InOut parameter. The value for the data type can be any one of the following data types, viz String, Amount, Number, Date OR Logical.
Scode
Number
String
0 to 4,294,967,295
This is a kind of an error code data type, used by Windows API.
The parameters can also be of the Other Permissible TDL data types, as mentioned in the table, in place of the data types mentioned in the column titled ‘TDL Data Type’. Irrespective of whether the parameter is an In, Out OR InOut parameter, Tally implicitly converts these data types to the respective COM Data Types.
In Release 4.6, while declaring the Parameters for COM Interface, only a limited number of data types could be accepted as data type for the parameter. Let’s understand this with the help of the following example:
DLL C o de
TDL Code - COM Interface Definition
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace MathLib
public class MathClass
public double Add(double pDouble)
return pDouble + 9;
[COM Interface : TSPL Smp Add]
Project : MathLib
Class : MathClass
Interface : Add
Parameters : p1 : Number : In
Returns : Number
In the codes shown in the table, the Interface Add of Class MathClass had the Parameter Data type as Double in DLL, while the same had to be mapped to Number as the Parameter Data type in TDL.
From Release 4.61 onwards, the COM Data Types listed in ‘Other Permissible TDL Data Types’ column in the table are also supported. Thus, in this particular example, the data type of the Parameter can also be specified as Double in place of Number, and hence, the same can be rewritten as:
Parameters : p1 : Double : In
However, while invoking the COM Server, the data type must be a TDL Data Type, viz. Number, String, Amount, Date OR Logical.
Example
[Function : TSPL Smp Addition]
Parameter : InputNo : Number
00 : Exec COM Interface : TSPL Smp Add : ##InputNo
10 : Log : $$LastResult
Note: It is not necessary to have the above TDL Data Type as Number. It could also be a String or an Amount. However, the value within the String should be a Number.
