https://help.tallysolutions.com/docs/td9rel54/dict_mgr/operations_in_dictionary_manager/using_operating_system_keyboard.htm
Using On-Screen Keyboard in Dictionary Manager
The On-Screen keyboard is a virtual keyboard which appears on the computer screen. Using the On-Screen keyboard will familiarise you with the Operating System keyboard’s layout.
To configure On-Screen Keyboard
1. Go to Start > Programs > Accessories > Accessibility .
2. Select Onscreen Keyboard .
The On-Screen Keyboard appears as shown below:
3. Use Alt + Shift to configure the language of your choice. For example, if you wish to enter data in Hindi, select Hindi using Alt + Shift or select the same from the language bar, as shown below:
The On-Screen Keyboard in Hindi appears as shown below:
