https://help.tallysolutions.com/docs/td9rel54/dict_mgr/operations_in_dictionary_manager/setting_dictionary_preferences.htm
Setting Dictionary Preferences
You can set the dictionary preferences by going to Tool > Preferences .
The Preferences screen appears as shown below:
In the Preferences screen, the following options are available:
Load the last opened dictionary whenever the dictionary manager is launched.
Automatically load the current language keyboard.
Activate phonetic keyboard whenever Dictionary Manager is launched.
